Wasn’t quite sure where to post this as the are not a look of Edison posts at this time. I currently have an APM 2.6 connected to a raspberry pi to do the telemetry via 3G. It’s works great.
I am trying to switch out the Raspberry PI for an Intel Edison (smaller) and I can’t get it fully working.
This is what I’ve done:
Flashed Edison with ubilinux: Works
add packages for OpenCV and all the required ones for mavlink
added mavproxy.
Here’s what is working.
Edison Boots up.
Can run mavproxy.py --master=/dev/ttyMFD1 --baudrate 57600 --out 10.5.96.16714550 --aircraft MyCopter
Everything starts fine.
I am getting the state of the APM
Here’s the problem,
When I open mission planner, I select UDP, verify the port number, and connect,
I connect and MP gets the mavlink heartbeat but then it hangs on “getting params”.
I have used screen to watch whats coming over via the uart and the traffic is there and looks good
Just curious if anyone has actually tried this setup or run into this problem.
Thanks in advance.
