Integrating OpenVINS with Ardupilot
I am working on integrating OpenVINS with an ArduPilot-based system using external vision as the primary navigation source.
Setup
  • Platform: ArduPilot (SITL / real vehicle)
  • VIO: OpenVINS publishing /ov_msckf/odomimu (Odometry)
  • Camera: mounted at ~45° tilt
  • ROS 2 environment
  • Previously used a custom MAVLink bridge to send:
    • VISION_POSITION_ESTIMATE
    • VISION_SPEED_ESTIMATE
What I’ve done
  • Converted OpenVINS output (Z-up frame) to NED and sent via MAVLink
  • Verified that VIO trajectory matches ground truth when GPS is enabled
  • Disabled GPS and configured EKF3 for external navigation:
    • EK3_SRC1_POSXY = 6
    • EK3_SRC1_POSZ = 6 (also tested with baro)
    • EK3_SRC1_VELXY = 6
    • EK3_SRC1_VELZ = 6
    • EK3_SRC1_YAW = 6
  • Set EKF origin at startup
  • Disabled compass (to avoid yaw conflicts)
  • Tuned EKF gates and noise parameters for VIO
Observed behavior
  • Vehicle takes off correctly and reaches target altitude
  • After reaching altitude, it starts rotating unexpectedly
  • Shortly after, EKF reports variance errors
  • System becomes unstable
Key observation
  • With GPS enabled → system is stable and trajectory matches ground truth
  • With GPS disabled (VIO only) → instability appears after takeoff
  • VIO itself appears accurate
Questions
  1. Is sending VISION_POSITION_ESTIMATE + VISION_SPEED_ESTIMATE directly sufficient, or is MAVROS /odometry/in recommended?
  2. Could this issue be caused by:
    • Frame mismatch (ENU vs NED, FLU vs FRD)?
    • Incorrect covariance values?
    • Improper yaw alignment or initialization?
    • Camera tilt (45°) not properly accounted for?
  3. Is there a recommended workflow for initializing EKF origin and yaw when using VIO-only (no GPS)?
  4. Are there specific EKF3 parameters that are critical for stable VIO-only operation beyond the standard EK3_SRC1_* settings?
Any guidance or debugging suggestions would be greatly appreciated.
