Hello! I’m trying to get MAVproxy on a raspberry PI, I was following the documentation but I’m getting an error when doing this command : pip3 install PyYAML mavproxy --user
For information, my pip --version is 23.0.1 and i’ve also tried to replace pip3 by only pip, don’t change anything.
Do you guys have any ideas?
Yuri_Rage
(Yuri Rage)
November 23, 2024, 1:09pm
2
You should use a virtual environment. If you don’t know how to do that, you can use pipx:
sudo apt install pipx
pipx install PyYAML mavproxy
Thank you! So I tried doing just that, but it gives me an error. It installed when I did :
but than with
it gives me this :
(in this screenshot I already installed pipx previously, as you can see)
I tried doing some research, but honestly I’m totally lost. Do you have any ideas?
Yuri_Rage
(Yuri Rage)
November 24, 2024, 2:24pm
4
Just separate the two packages into two different install commands.
Thanks! It worked with mavproxy - pipx install mavproxy
And for PyYAML I ended up doing : sudo apt install python3-yaml
