[quote=“gabek”]Nice!
While i was going trough parameters, have noticed that, INS_PRODUCT_ID reads 0 on my APM 1.4 and it seams that i can change it.
[/quote]
On a 2560 based APM1.4 board the INS_PRODUCT_ID should be 2. If you change it then it will change back when you next reset the board.
Unfortunately you can’t upgrade your hardware by setting that parameter
Cheers, Tridge
[quote=“tridge”][quote=“gabek”]Nice!
[/quote]
Cheers, Tridge[/quote]
Sure,
But it reads 0, even after a factory reset, end erase.
Also i think i can change it, and it keeps the value.
Does it has an effect on anything?
If not, i will not care, but go fly!
That’s very strange! I just tested on a APM1 1.4 board and it gave 2.
Is there any chance you’ve loaded the HIL firmware? That would give 0.
If not, can you post a tlog?
Cheers, Tridge
Hi Gabek,
Thanks for the logs. I’ve worked out how this happens and I’ll fix in git master. Basically on your board the delay we do to print “beginning INS calibration; do not move plane” is long enough for MAVLink to transfer the uninitialised INS_PRODUCT_ID.
The bug is harmless, so I think it’s fine for you to fly. Thanks for telling me though!
Cheers, Tridge
