I’m new to all of this.
I’m setting up a Pixhawk with APMPlane 3.0.3, Ublox GPS, 3DR power module + 3S lipo, servo rail powered from ESC BEC. I’m using a traditional JR PWM radio via the 3DR PPM encoder.
I get different (big) LED indications for different startups. On “good” starts I have servo control from the radio and can connect Mission Planner OK.
On “bad” starts I have servo control from the radio but cannot connect MP, it times out.
A good start led sequence is: White, Yellow flash, Red/Blue flash. Yellow double flash, Yellow single flash, solid Blue then single low tone.
On a bad start the led sequence is: White, Yellow flash, Red/Blue flash, solid Red.
I may do two or three bad starts before I get a good start. I’ve also noticed that the Pixhawk leds are much brighter and that startup seems to take longer when powered from the PM. They are dimmer and the startup is faster when powered from USB. Plugging in the USB after a power up from PM also makes the leds dim.
I can’t find any reference to what the Red led is indicating (or to what the single low tone means).
So, is this normal behavior or should I be checking something in my setups?
Thanks,
Dave
