Hello. I am currently building a VTOL tilt-wing aircraft using Pixhawk4, Mission Planner, and ArduPilot. When flying in Q-stabilize mode on Mission Planner, I cannot control yaw. Is there a solution for this issue? As soon as the aircraft takes off, it rotates counterclockwise, making one full turn every two seconds, and I cannot control the yaw with the controler. In Q-loiter mode, there is still some yawing, but it is less severe compared to Q-stabilize mode.
How far along the tuning process have you gone?
https://ardupilot.org/plane/docs/quadplane-vtol-tuning-process.html
You haven’t given any details of your set up. Are you using tilt vectored yaw control? If so, have you tuned that?
https://ardupilot.org/plane/docs/tilt-vectored-yaw-tuning.html
You can also post the .bin log file of the test flight, that can give us some clues to help you. Without a .bin file it’s really difficult to help.
Thanks for your help sir, i will do it tomorrow. it’s my first time making Quadcopter, so i am not good at it
