In FBWA mode, the engine starts with full throttle
friends, tell me what the problem may be, I switch to FBWA mode, the gas is controlled normally, if I make the following switch as in the video to FBWA mode or if FBWB is installed, then the motor starts at 100% and the gas does not obey. This happens if Q - VTOL Mode is enabled, if Q mode is disabled, then everything works correctly. I changed the firmware to the latest stable one and set everything up again, it’s still the same https://youtube.com/shorts/yMQvpXaOLyo?si=JhLbdWiVA--EbWWc
It may be caused by the plane thinking it is flying, FBWB is speed& altitude control mode so it tries to reach target speed and altitude. If you don’t have pitot probe it sets cruise throttle and allows nudging above mid stick.
Plane may be affecting is flying logic making it more sensitive.
If you have a VTOL you should takeoff in Q_STABILIZE (before completing setup and tuning) or Q_LOITER (after tuning) for vertical takeoff or in Manual (before setup) or TAKEOFF (after setup) for FW takeoff.
IIRC in Q_OPTIONS there are bits to inhibit fixed wing takeoff and landing.
The pitot tube is not connected yet, I did not know about the Q_OPTIONS bits for prohibiting takeoff and landing of fixed-wing aircraft, thank you for reassuring me).
I just can’t understand why in FBWA mode 1 the gas can be controlled from the remote, but if you turn on mode 5, even if you also put FBWA mode there, the motors immediately start at 100% gas and are not controlled from the remote, the mode is one FBWA
I have already set up a vertical takeoff, it remains to check the horizontal flight
You need to save flight mode settings for them to take effect.
FBWB provides speed and altitude control. Without pitot probe or synthetic airspeed it is quite rudimentary but there is no longer direct connection between stick throttle and autopilot output. Throttle increase should happen above mid stick position.
I had built VTOL before and there was no such problem, but thanks anyway for wanting to help. Here’s my drone
interestingly, if I turn off Q_ENABLE - Disable, then the problem goes away and the gas in airplane modes works as usual, I can control the gas in any flight mode
Are you using Pixhawk Flight controller?
no, I’m using CUAV X7, I didn’t solve the problem, but turned on Q_OPTIONS to exclude accidental activation of airplane mode on the ground. took the advice of dear LupusTheCanine)
