Improving landing of turbine plane
I am working on improving a turbine plane landing. It successfully landed once which is an accomplishment! On the same run, I took off and tried landing again, but the plane had a large pitch down (-6deg) near the ground which made forced an abort landing. I am using Here4 gps and RTK correction to improve the height estimate.
Both landing are on the same log file. Would appreciate suggestions on how to improve the landing. In particular:
  • how can I avoid the large pitch down close to the ground? I suspect it is because h is above demanded h. Do I just flare higher/earlier
  • Not sure why TECS_APPR_SMAX does not seem to be followed during approach
  • how to reduce the large oscillation in pitch during approach, should I increase TECS_LAND_TCONST?
Here is the log file
Thank you
maybe you could reference the discuss in
Thanks for the reference, I believe the dropping of dhdem during flare contributes to the problem on my aircraft too.
I am trying to merge the code change and build the firmware myself like you did, but I am struggling with the steps. In particular, I managed to build and upload arduplane 4.8-dev onto cube orange from my local repo, but I am not sure how to build and merge changes using arduplane 4.6.3. Would you be able to share any useful weblinks or steps for this? Thank you
  1. clone the code
  2. switch branch to tag plane-4.6.3
  3. merge the fixed code
  4. done
Thanks for the guidance. Do the steps below look correct?
I managed to build the custom firmware with these commands in WSL ubuntu:
git clone ‘https://github.com/ArduPilot/ardupilot.git’
cd ardupilot
git checkout Plane-4.6.3
git switch -c Plane-4.6.3
git branch (to check current branch)
git fetch ‘https://github.com/ArduPilot/ardupilot.git’ pull/31610/head
git config –global user.email “myemail”
git config –global user.name “myname”
git cherry-pick FETCH_HEAD
git submodule update –init –recursive
Tools/environment_install/install-prereqs-ubuntu.sh -y
. ~/.profile
(shutdown and restart WSL ubuntu)
./waf configure –board CubeOrangePlus
./waf plane
(upload build/CubeOrangePlus/bin/arduplane.apj to board using mission planner)
Thank you
