Hello guys,
I have a question about velocity command in axis z in Guided mode.
I’m using ArduCopter4.1.1
when I use the velocity command in axis z, the desired command has got a lot of delay and it doesn’t get steady in a certain time.
You Know, I’d like the desired velocity command to be as sharp as
possible and to be applied in step command; So that no smoother slows it down.
Do you have any solution for that?
Yes, I have read But Which part should I tune?
Do PID parameters also affect the desired value?( which params?)
I like to see the control diagram block implemented to execute velocity commands in axis z in Guided mode. can you help me, please?
