Impossible to upload the new geofence in copter 4.0.1 in holybro pixhawk 4
The geofence is not uploading in copter 4.0.1. It shows " This vehicle does not support geofence" in QGroundControl and in Mission Planner the marking and uploading of polygon is not working.
Thanks for the report. These issues are really down to the GCS developers so they are a bit out of my hands.
Here’s the issues that I know about for MP. @meee1 says that he’s resolved them but I haven’t yet gone back to check.
I’ve raised the issue with QGC here although the issue has been closed, I think it still persists. Maybe @DonLakeFlyer has some input.
I think the best thing to do is perhaps comment on the two issues above.
@Gourav1997,
I’ve retested the latest Beta MP and it does appear that it can upload and download all the fence types. It can be a little fiddly but it can be done. Below is a screen shot of two inclusion polygons, one inclusion circle and one exclusion circle.
What’s especially tricky is when you enter a polygon you must then type the number of points in the polygon into each row’s “Points” field.
Ok thanks. But what can be done with QGroundControl because i was planning to use Herelink with my PX4.
Try the Daily Build of QGC.
I am also facing the same issue when I try to upload a geofence using mission planner it does not upload an shows there was an unexpected error it but if I try to upload using the USB cable it uploads perfectly. I have read a couple of reply on various forums and figure out it is due to some telemetry does not support the mavlink2 protocol. I have set serial port protocol as mavlink 2 still no luck. I am using 2.4 Ghz communication using wifi and even if I try to upload it using . Does anyone know how I can fix this?
Forgot to mention I am on ardupilot copter 4.0.3 V firmware.
