Identifying reason for crash
So yesterday I was flying and messing around with the precision loiter function, but I ended up with a soft crash and I don’t know the reason. I was at a stable hover, but then suddenly started getting “telemetry lost” messages. The telemetry kept getting lost and found, going back and forth for a couple of minutes, then when it stabilized, I enabled land flight mode, but the drone just cut off the motors and fell about 2 meters to the grass below.
While it was hovering, I had the CV script running, and the marker below was successfully detected as I was watching the live video stream. I believe that the telemetry started oscillating when I executed the script, but I’m not 100% certain.
I also don’t know if it was human error, or something else… it could be human error, in that I didn’t monitor the battery close enough, but when I get low battery, the motors don’t just cut off all of a sudden. The drone should just land, since that’s the battery fail safe. On the other hand, it could be related to the telemetry issue, but I can’t pinpoint the specific reason from the logs. I think I identified the telemetry dropouts in the logs, but I’m not sure how to proceed from there.
From the log, I noticed that there are huge spikes in current that I don’t think are normal. I usually pull approx. 15A at hover, with some 20A spikes, so they do look unusual. However, they might be the result of acquiring the target when enabling precLoiter, but I’m not sure. Any input or insight from you guys will be helpful!
I have uploaded the log file for the crash, so hopefully someone can point me in the right direction. I also uploaded another log of a nominal flight I did right after the crash. This flight was after I visually inspected the craft, cleaned it off, and confirmed that all components were good, locked down, and that the frame remained rigid. I made sure to do a hover in AltHold to have a baseline to compare with.
FC: Pixhawk 6C
ESC: RDQ DShot1200 30A
Motors: SunnySky X2212 KV980
Frame: Official DJI F450 (not the knockoff version)
Props: Holybro 1045 (I also have a set of Airscrew 1045)
CC: RPi 5
Battery: 3s, one 3200mAh and another that’s 4200mAh
Looks like you entered Rapid Return To Earth Mode. Switched to Stabilize, throttle down.
Today, the same thing happened, randomly. My telemetry started failing, then all of a sudden, I fell out the sky again. I flew the entire day today with no issues, until one of my final flights, the same issue popped up. This time, when I plot the VIBE it’s much more noticeable, but I am still lost on the culprit.
All I can see in the log is the point where the dropout happens. Other than that, everything looks just like a nominal log where the mission was successful.
It’s weird because I thought that the telemetry link is independent of something like the motors… why would the motors cut off if I lose one telemetry link? Me losing one telemetry link shouldn’t affect the craft from landing, should it? It must be a wiring issue or some other hardware/electrical issue. After the crash, the FC acted funny and had problems booting up, so I’m almost certain its some kind of electrical issue. I had to reboot like twice because it kept printing ‘Ardupilot initializing’ in MP.
Im going to update to the newest firmware, and keep testing. Then if it happens again, I guess Im going to have to deconstruct the craft and get into the nooks and crannies lol.
The end result was the same in this log as the last. Switch to Stabilize, throttle down, down it goes. But the cause seems to be a problem with your RC System dropping out. It’s diffult to see what’s going on here but all RC inputs go low which switches modes and drops the throttle. Plot it for yourself and see. In fact view the entire flight this way there are several occasions where they all spike low.
What kind of radio system are you using? What TX and RX?
Well, it’s Fport…
Im using a FRsky taranis X9 lite Tx with an Archer M+ mini Rx.
Interesting… the plot looks much clearer with this combo of curves. Thanks!
I guess im going to start looking at the Tx and Rx as my prime suspects then. My Tx antenna is a bit shot, so it might be that, but it usually works good. Its just a bit bent. I did replace the inner RTC battery recently, though, so maybe I messed something up when I opened it up.
Yea, something is causing intermittent failure.
Check what failsafe options you have with that receiver (in the transmitter settings) - you may be able to set “No Pulses” which is ideal.
If the only option is that channels are set the way they were when the TX and RX were bound, then you need to trim the throttle way down as low as it will go and set mode switches to Loiter or RTL then do the binding procedure again. Put the throttle trim back to centered (normal) after binding.
DO not do a radio calibration while the throttle is trimmed very low.
Check that setting the throttle low does actually cause an throttle/RC failsafe. If necessary adjust FS_THR_VALUE,970 so it is about 20 higher that what the low throttle will achieve.
This wont stop your Tx and Rx disconnecting, but it will ensure the correct action when it does.
Using a tool it detected that you have a severe battery sag. And a spike on your GPS/compass. Have you done a compass calibration with motors on? I have had similar behaviors that go away with a compass motor calibration and is this an older battery? Watch it’s curve compared to a similar one that you have to see if it is misbehaving
Your “tool” didn’t catch that the battery “sag” was when it hit the ground. And Compass Motor Calibration is done thru Magfit. I don’t think there is any mystery as to what happened here based on a human looking at a log graph…
I think you could have framed your thought, "I don’t think that is the issue " in a different way to get people like me to dig deeper or continue to contribute in this forum. We all pitch in based on our experience, and we get things wrong. Best of luck and look forward to hearing the reason to watch out for such incidents on my builds.
Those reasons were posted. Using some tool (what tool?) blindly and posting its output is not at all helpful. Sure, use whatever tool you like and then confirm based on experience if it’s reasonable or not.
