Hello community,
I am writing because I am having a problem with the motors of my hexacopter drone. After doing an esc calibration, I ran an engine ignition test (without propellers as I wasn’t sure of the likely outcome of it), but unfortunately when I accelerate gradually, a random engine does not continue with its “acceleration”. If I repeat the same procedure, another motor at random behaves in the same way, thus always remaining with 5 motors running.
Also, I encountered the “CRASH: DISARMING” error which caused all engines to shut down instantly (luckily I didn’t fly !!!)
I would like some clarification on how to solve this problem.
Thank you in advance for your availability.
PS: below the text of the logs!
Log File C:\Users\Alfio Zammataro\Desktop\APM\LOGS\HEXAROTOR\1\2021-03-11 12-00-53.log
Size (kb) 5200.0673828125
No of lines 61493
Duration 0:03:59
Vehicletype ArduCopter
Firmware Version V4.0.3
Firmware Hash ffd08628
Hardware Type
Free Mem 0
Skipped Lines 0
Test: Brownout = GOOD -
Test: Compass = GOOD - mag_field interference within limits (3.48%)
Test: Dupe Log Data = GOOD -
Test: Empty = GOOD -
Test: Event/Failsafe = FAIL - ERRs found: FS_THR CRASH
Test: GPS = GOOD -
Test: IMU Mismatch = NA -
Test: Motor Balance = FAIL - Motor channel averages = [1413, 1485, 1514, 1364, 1310, 1468]
Average motor output = 1425
Difference between min and max motor averages = 204
Test: NaNs = FAIL - Found NaN in CTUN.DSAlt
Test: OpticalFlow = FAIL - FAIL: no optical flow data
Test: Parameters = FAIL - ‘MAG_ENABLE’ not found
Test: PM = GOOD -
Test: Pitch/Roll = GOOD -
Test: Thrust = GOOD -
Test: VCC = UNKNOWN - No CURR log data
