bool AP_GPS_Blended::get_lag(float &lag_sec) const
lag_sec = _blended_lag_sec;
// auto switching uses all GPS receivers, so all must be configured
uint8_t inst; // we don't actually care what the number is, but must pass it
return gps.first_unconfigured_gps(inst);
bool AP_GPS::first_unconfigured_gps(uint8_t &instance) const
for (int i = 0; i < GPS_MAX_RECEIVERS; i++) {
if (params[i].type != GPS_TYPE_NONE && (drivers[i] == nullptr || !drivers[i]->is_configured())) {
instance = i;
return true;
return false;
This is code, my arducopter version is 4.6.1, but I see master and 4.7 also like too.
In my understanding, If the GPS is not initialized, first_unconfigured_gps will return true, then get_lag also return true. However, I think get_lag should return false when GPS is not initialized.
So is it my misunderstanding, or is the code error?
In bool NavEKF3_core::setup_core(uint8_t _imu_index, uint8_t _core_index) function
// GPS sensing can have large delays and should not be included if disabled
if (frontend->sources.usingGPS()) {
// Wait for the configuration of all GPS units to be confirmed. Until this has occurred the GPS driver cannot provide a correct time delay
float gps_delay_sec = 0;
if (!dal.gps().get_lag(selected_gps, gps_delay_sec)) {
#if HAL_GCS_ENABLED
const uint32_t now = dal.millis();
if (now - lastInitFailReport_ms > 10000) {
lastInitFailReport_ms = now;
// provide an escalating series of messages
MAV_SEVERITY severity = MAV_SEVERITY_INFO;
if (now > 30000) {
severity = MAV_SEVERITY_ERROR;
} else if (now > 15000) {
severity = MAV_SEVERITY_WARNING;
GCS_SEND_TEXT(severity, "EKF3 waiting for GPS config data");
#endif
return false;
// limit the time delay value from the GPS library to a max of 250 msec which is the max value the EKF has been tested for.
maxTimeDelay_ms = MAX(maxTimeDelay_ms , MIN((uint16_t)(gps_delay_sec * 1000.0f),250));
GCS will print warning info when get_lag = false. So I think when GPS not configured, get_lag() should return false.
Verify that the cited line dal.gps().get_lag(selected_gps, gps_delay_sec) could possibly call to the AP_GPS_Blended::get_lag( ) that you’re looking at.
Again, I’m no expert, but it looks to me like that would call to AP_DAL_GPS::get_lag( ) which is a different function. (And might have different specified return behavior.)
