Hello.
I’m trying transmitter-based tuning to fine-tune my helicopter’s PID settings again, but I get an error message saying “Invalid channel option.”
The reference material I am using is probably for a multicopter, and I am having difficulty setting it up because my current mission planner does not allow me to switch to “Extended tuning.”
I don’t think this makes a difference. I have a Cube Orange on the bench with Trade Heli loaded and I can set the Tune parameters in either the Extended Tune screen or the Full Parameter list.
@itagaki-jetset So is the reversed option set (RC6_REVERSE set to 1) on that channel? If it is then I think that is the issue. Set it back to 0 and see if the warning goes away.
Please post your parameters. That may make this a little easier
20250417_01param.param (19.8 KB)
This is the current parameter being changed.
RC6 is not set to reverse (1).
This is the same setting on the transmitter side.
In this version of AC, transmitter tuning will only work on channel 6. In later versions of AC transmitter tuning can be assigned to any channel, but you need to adjust the options accordingly.
