Is this the log that you want?
“HEARTBEAT” : { “type”: 2 ,“autopilot”: 3 ,“base_mode”: 209 ,“custom_mode”: 2 ,“system_status”: 4 ,“mavlink_version”: 3 ,"_seq" : 176, “_sysid” : 1, “_compid” : 1, “_age” : 498},
“EKF_STATUS_REPORT” : { “flags”: 485 ,“velocity_variance”: 0.000000 ,“pos_horiz_variance”: 0.000413 ,“pos_vert_variance”: 0.013717 ,“compass_variance”: 0.172656 ,“terrain_alt_variance”: 0.008505 ,"_seq" : 222, “_sysid” : 1, “_compid” : 1, “_age” : 118},
“STATUSTEXT” : { “severity”: 6 ,“text”: “EKF2 IMU0 in-flight yaw alignment complete” ,"_seq" : 153, “_sysid” : 1, “_compid” : 1, “_age” : 680},
“SYS_STATUS” : { “onboard_control_sensors_present”: 52558895 ,“onboard_control_sensors_enabled”: 52542511 ,“onboard_control_sensors_health”: 35781679 ,“load”: 459 ,“voltage_battery”: 3838 ,“current_battery”: -1 ,“battery_remaining”: -1 ,“drop_rate_comm”: 0 ,“errors_comm”: 0 ,“errors_count1”: 0 ,“errors_count2”: 0 ,“errors_count3”: 0 ,“errors_count4”: 0 ,"_seq" : 204, “_sysid” : 1, “_compid” : 1, “_age” : 208},
“RC_CHANNELS” : { “time_boot_ms”: 91262 ,“chancount”: 11 ,“chan1_raw”: 1497 ,“chan2_raw”: 1498 ,“chan3_raw”: 1505 ,“chan4_raw”: 1498 ,“chan5_raw”: 1995 ,“chan6_raw”: 1005 ,“chan7_raw”: 1005 ,“chan8_raw”: 198 ,“chan9_raw”: 19 ,“chan10_raw”: 100 ,“chan11_raw”: 22 ,“chan12_raw”: 0 ,“chan13_raw”: 0 ,“chan14_raw”: 0 ,“chan15_raw”: 0 ,“chan16_raw”: 0 ,“chan17_raw”: 0 ,“chan18_raw”: 0 ,“rssi”: 252 ,"_seq" : 213, “_sysid” : 1, “_compid” : 1, “_age” : 190},
“ATTITUDE” : { “time_boot_ms”: 91262 ,“roll”: -0.002145 ,“pitch”: 0.007048 ,“yaw”: 0.097635 ,“rollspeed”: 0.001910 ,“pitchspeed”: 0.000133 ,“yawspeed”: 0.004425 ,"_seq" : 214, “_sysid” : 1, “_compid” : 1, “_age” : 190},
“GPS_RAW_INT” : { “time_usec”: 0 ,“fix_type”: 1 ,“lat”: 290114965 ,“lon”: -821191546 ,“alt”: 44870 ,“eph”: 9999 ,“epv”: 9999 ,“vel”: 0 ,“cog”: 0 ,“satellites_visible”: 0 ,"_seq" : 208, “_sysid” : 1, “_compid” : 1, “_age” : 214},
“RAW_IMU” : { “time_usec”: 91221200 ,“xacc”: 6 ,“yacc”: 3 ,“zacc”: -1001 ,“xgyro”: 0 ,“ygyro”: 0 ,“zgyro”: 5 ,“xmag”: 185 ,“ymag”: -72 ,“zmag”: 361 ,"_seq" : 201, “_sysid” : 1, “_compid” : 1, “_age” : 236},
“SCALED_PRESSURE” : { “time_boot_ms”: 91221 ,“press_abs”: 1012.806 ,“press_diff”: -0.563437 ,“temperature”: 6189 ,"_seq" : 202, “_sysid” : 1, “_compid” : 1, “_age” : 240},
“VFR_HUD” : { “airspeed”: 0.000000 ,“groundspeed”: 0.032176 ,“heading”: 5 ,“throttle”: 0 ,“alt”: 0.000000 ,“climb”: 0.000000 ,"_seq" : 217, “_sysid” : 1, “_compid” : 1, “_age” : 158}}
“HEARTBEAT” : { “type”: 2 ,“autopilot”: 3 ,“base_mode”: 209 ,“custom_mode”: 2 ,“system_status”: 4 ,“mavlink_version”: 3 ,"_seq" : 12, “_sysid” : 1, “_compid” : 1, “_age” : 704},
“EKF_STATUS_REPORT” : { “flags”: 485 ,“velocity_variance”: 0.000000 ,“pos_horiz_variance”: 0.000963 ,“pos_vert_variance”: 0.001623 ,“compass_variance”: 0.065639 ,“terrain_alt_variance”: 0.020859 ,"_seq" : 55, “_sysid” : 1, “_compid” : 1, “_age” : 266},
“STATUSTEXT” : { “severity”: 6 ,“text”: “EKF2 IMU0 in-flight yaw alignment complete” ,"_seq" : 153, “_sysid” : 1, “_compid” : 1, “_age” : 1898},
“SYS_STATUS” : { “onboard_control_sensors_present”: 52558895 ,“onboard_control_sensors_enabled”: 52542511 ,“onboard_control_sensors_health”: 52558895 ,“load”: 650 ,“voltage_battery”: 3837 ,“current_battery”: -1 ,“battery_remaining”: -1 ,“drop_rate_comm”: 0 ,“errors_comm”: 0 ,“errors_count1”: 0 ,“errors_count2”: 0 ,“errors_count3”: 0 ,“errors_count4”: 0 ,"_seq" : 59, “_sysid” : 1, “_compid” : 1, “_age” : 170},
“RC_CHANNELS” : { “time_boot_ms”: 92527 ,“chancount”: 11 ,“chan1_raw”: 1497 ,“chan2_raw”: 1497 ,“chan3_raw”: 1505 ,“chan4_raw”: 1498 ,“chan5_raw”: 1995 ,“chan6_raw”: 1005 ,“chan7_raw”: 1005 ,“chan8_raw”: 198 ,“chan9_raw”: 18 ,“chan10_raw”: 98 ,“chan11_raw”: 22 ,“chan12_raw”: 0 ,“chan13_raw”: 0 ,“chan14_raw”: 0 ,“chan15_raw”: 0 ,“chan16_raw”: 0 ,“chan17_raw”: 0 ,“chan18_raw”: 0 ,“rssi”: 252 ,"_seq" : 68, “_sysid” : 1, “_compid” : 1, “_age” : 134},
“ATTITUDE” : { “time_boot_ms”: 92544 ,“roll”: -0.002161 ,“pitch”: 0.006893 ,“yaw”: 0.100758 ,“rollspeed”: 0.004418 ,“pitchspeed”: -0.006084 ,“yawspeed”: 0.016857 ,"_seq" : 69, “_sysid” : 1, “_compid” : 1, “_age” : 134},
“GPS_RAW_INT” : { “time_usec”: 0 ,“fix_type”: 1 ,“lat”: 290114965 ,“lon”: -821191546 ,“alt”: 44870 ,“eph”: 9999 ,“epv”: 9999 ,“vel”: 0 ,“cog”: 0 ,“satellites_visible”: 0 ,"_seq" : 63, “_sysid” : 1, “_compid” : 1, “_age” : 168},
“RAW_IMU” : { “time_usec”: 92442203 ,“xacc”: 12 ,“yacc”: 9 ,“zacc”: -1001 ,“xgyro”: 0 ,“ygyro”: 1 ,“zgyro”: 19 ,“xmag”: 189 ,“ymag”: -79 ,“zmag”: 361 ,"_seq" : 57, “_sysid” : 1, “_compid” : 1, “_age” : 200},
“SCALED_PRESSURE” : { “time_boot_ms”: 92442 ,“press_abs”: 1012.815 ,“press_diff”: -0.554140 ,“temperature”: 6191 ,"_seq" : 58, “_sysid” : 1, “_compid” : 1, “_age” : 200},
“VFR_HUD” : { “airspeed”: 0.000000 ,“groundspeed”: 0.050216 ,“heading”: 5 ,“throttle”: 0 ,“alt”: 0.300000 ,“climb”: 0.020000 ,"_seq" : 72, “_sysid” : 1, “_compid” : 1, “_age” : 10}}
“HEARTBEAT” : { “type”: 2 ,“autopilot”: 3 ,“base_mode”: 209 ,“custom_mode”: 2 ,“system_status”: 4 ,“mavlink_version”: 3 ,"_seq" : 110, “_sysid” : 1, “_compid” : 1, “_age” : 920},
“EKF_STATUS_REPORT” : { “flags”: 485 ,“velocity_variance”: 0.000000 ,“pos_horiz_variance”: 0.001786 ,“pos_vert_variance”: 0.008805 ,“compass_variance”: 0.040032 ,“terrain_alt_variance”: 0.024089 ,"_seq" : 175, “_sysid” : 1, “_compid” : 1, “_age” : 198},
“STATUSTEXT” : { “severity”: 6 ,“text”: “EKF2 IMU0 in-flight yaw alignment complete” ,"_seq" : 153, “_sysid” : 1, “_compid” : 1, “_age” : 3194},
“SYS_STATUS” : { “onboard_control_sensors_present”: 52558895 ,“onboard_control_sensors_enabled”: 52542511 ,“onboard_control_sensors_health”: 35781679 ,“load”: 408 ,“voltage_battery”: 3830 ,“current_battery”: -1 ,“battery_remaining”: -1 ,“drop_rate_comm”: 0 ,“errors_comm”: 0 ,“errors_count1”: 0 ,“errors_count2”: 0 ,“errors_count3”: 0 ,“errors_count4”: 0 ,"_seq" : 186, “_sysid” : 1, “_compid” : 1, “_age” : 40},
“RC_CHANNELS” : { “time_boot_ms”: 93785 ,“chancount”: 11 ,“chan1_raw”: 1497 ,“chan2_raw”: 1497 ,“chan3_raw”: 1507 ,“chan4_raw”: 1498 ,“chan5_raw”: 1995 ,“chan6_raw”: 1005 ,“chan7_raw”: 1005 ,“chan8_raw”: 198 ,“chan9_raw”: 18 ,“chan10_raw”: 99 ,“chan11_raw”: 22 ,“chan12_raw”: 0 ,“chan13_raw”: 0 ,“chan14_raw”: 0 ,“chan15_raw”: 0 ,“chan16_raw”: 0 ,“chan17_raw”: 0 ,“chan18_raw”: 0 ,“rssi”: 252 ,"_seq" : 179, “_sysid” : 1, “_compid” : 1, “_age” : 174},
“ATTITUDE” : { “time_boot_ms”: 93785 ,“roll”: -0.001872 ,“pitch”: 0.007238 ,“yaw”: 0.104383 ,“rollspeed”: -0.002858 ,“pitchspeed”: 0.002378 ,“yawspeed”: -0.030122 ,"_seq" : 180, “_sysid” : 1, “_compid” : 1, “_age” : 164},
“GPS_RAW_INT” : { “time_usec”: 0 ,“fix_type”: 1 ,“lat”: 290114965 ,“lon”: -821191546 ,“alt”: 44870 ,“eph”: 9999 ,“epv”: 9999 ,“vel”: 0 ,“cog”: 0 ,“satellites_visible”: 0 ,"_seq" : 190, “_sysid” : 1, “_compid” : 1, “_age” : 44},
“RAW_IMU” : { “time_usec”: 93905326 ,“xacc”: 8 ,“yacc”: 2 ,“zacc”: -999 ,“xgyro”: 2 ,“ygyro”: 0 ,“zgyro”: 17 ,“xmag”: 203 ,“ymag”: -85 ,“zmag”: 361 ,"_seq" : 183, “_sysid” : 1, “_compid” : 1, “_age” : 58},
“SCALED_PRESSURE” : { “time_boot_ms”: 93905 ,“press_abs”: 1012.808 ,“press_diff”: -0.561406 ,“temperature”: 6193 ,"_seq" : 184, “_sysid” : 1, “_compid” : 1, “_age” : 58},
“VFR_HUD” : { “airspeed”: 0.000000 ,“groundspeed”: 0.061495 ,“heading”: 5 ,“throttle”: 0 ,“alt”: 0.230000 ,“climb”: 0.020000 ,"_seq" : 170, “_sysid” : 1, “_compid” : 1, “_age” : 222}}
“HEARTBEAT” : { “type”: 2 ,“autopilot”: 3 ,“base_mode”: 209 ,“custom_mode”: 2 ,“system_status”: 4 ,“mavlink_version”: 3 ,"_seq" : 28, “_sysid” : 1, “_compid” : 1, “_age” : 246},
“EKF_STATUS_REPORT” : { “flags”: 485 ,“velocity_variance”: 0.000000 ,“pos_horiz_variance”: 0.002779 ,“pos_vert_variance”: 0.002033 ,“compass_variance”: 0.054735 ,“terrain_alt_variance”: 0.027475 ,"_seq" : 43, “_sysid” : 1, “_compid” : 1, “_age” : 126},
“STATUSTEXT” : { “severity”: 6 ,“text”: “EKF2 IMU0 in-flight yaw alignment complete” ,"_seq" : 153, “_sysid” : 1, “_compid” : 1, “_age” : 4502},
“SYS_STATUS” : { “onboard_control_sensors_present”: 52558895 ,“onboard_control_sensors_enabled”: 52542511 ,“onboard_control_sensors_health”: 35781679 ,“load”: 426 ,“voltage_battery”: 3823 ,“current_battery”: -1 ,“battery_remaining”: -1 ,“drop_rate_comm”: 0 ,“errors_comm”: 0 ,“errors_count1”: 0 ,“errors_count2”: 0 ,“errors_count3”: 0 ,“errors_count4”: 0 ,"_seq" : 45, “_sysid” : 1, “_compid” : 1, “_age” : 128},
“RC_CHANNELS” : { “time_boot_ms”: 95040 ,“chancount”: 11 ,“chan1_raw”: 1497 ,“chan2_raw”: 1498 ,“chan3_raw”: 1396 ,“chan4_raw”: 1498 ,“chan5_raw”: 1995 ,“chan6_raw”: 1005 ,“chan7_raw”: 1005 ,“chan8_raw”: 198 ,“chan9_raw”: 18 ,“chan10_raw”: 97 ,“chan11_raw”: 22 ,“chan12_raw”: 0 ,“chan13_raw”: 0 ,“chan14_raw”: 0 ,“chan15_raw”: 0 ,“chan16_raw”: 0 ,“chan17_raw”: 0 ,“chan18_raw”: 0 ,“rssi”: 252 ,"_seq" : 31, “_sysid” : 1, “_compid” : 1, “_age” : 232},
“ATTITUDE” : { “time_boot_ms”: 95040 ,“roll”: -0.001522 ,“pitch”: 0.006975 ,“yaw”: 0.104731 ,“rollspeed”: 0.006516 ,“pitchspeed”: 0.007429 ,“yawspeed”: -0.006170 ,"_seq" : 32, “_sysid” : 1, “_compid” : 1, “_age” : 234},
“GPS_RAW_INT” : { “time_usec”: 0 ,“fix_type”: 1 ,“lat”: 290114965 ,“lon”: -821191546 ,“alt”: 44870 ,“eph”: 9999 ,“epv”: 9999 ,“vel”: 0 ,“cog”: 0 ,“satellites_visible”: 0 ,"_seq" : 49, “_sysid” : 1, “_compid” : 1, “_age” : 134},
“RAW_IMU” : { “time_usec”: 95121503 ,“xacc”: 3 ,“yacc”: 2 ,“zacc”: -1002 ,“xgyro”: 3 ,“ygyro”: -6 ,“zgyro”: 0 ,“xmag”: 186 ,“ymag”: -92 ,“zmag”: 362 ,"_seq" : 35, “_sysid” : 1, “_compid” : 1, “_age” : 158},
“SCALED_PRESSURE” : { “time_boot_ms”: 95121 ,“press_abs”: 1012.819 ,“press_diff”: -0.550390 ,“temperature”: 6195 ,"_seq" : 36, “_sysid” : 1, “_compid” : 1, “_age” : 156},
“VFR_HUD” : { “airspeed”: 0.000000 ,“groundspeed”: 0.087087 ,“heading”: 6 ,“throttle”: 0 ,“alt”: 0.190000 ,“climb”: 0.020000 ,"_seq" : 37, “_sysid” : 1, “_compid” : 1, “_age” : 158}}
“HEARTBEAT” : { “type”: 2 ,“autopilot”: 3 ,“base_mode”: 209 ,“custom_mode”: 2 ,“system_status”: 4 ,“mavlink_version”: 3 ,"_seq" : 119, “_sysid” : 1, “_compid” : 1, “_age” : 562},
“EKF_STATUS_REPORT” : { “flags”: 485 ,“velocity_variance”: 0.000000 ,“pos_horiz_variance”: 0.003537 ,“pos_vert_variance”: 0.003506 ,“compass_variance”: 0.059958 ,“terrain_alt_variance”: 0.025636 ,"_seq" : 162, “_sysid” : 1, “_compid” : 1, “_age” : 108},
“STATUSTEXT” : { “severity”: 6 ,“text”: “Tmode: throttle disarm” ,"_seq" : 156, “_sysid” : 1, “_compid” : 1, “_age” : 140},
“SYS_STATUS” : { “onboard_control_sensors_present”: 52558895 ,“onboard_control_sensors_enabled”: 52542511 ,“onboard_control_sensors_health”: 35781679 ,“load”: 428 ,“voltage_battery”: 3817 ,“current_battery”: -1 ,“battery_remaining”: -1 ,“drop_rate_comm”: 0 ,“errors_comm”: 0 ,“errors_count1”: 0 ,“errors_count2”: 0 ,“errors_count3”: 0 ,“errors_count4”: 0 ,"_seq" : 149, “_sysid” : 1, “_compid” : 1, “_age” : 226},
“RC_CHANNELS” : { “time_boot_ms”: 96532 ,“chancount”: 11 ,“chan1_raw”: 1497 ,“chan2_raw”: 1498 ,“chan3_raw”: 1148 ,“chan4_raw”: 1498 ,“chan5_raw”: 1995 ,“chan6_raw”: 1005 ,“chan7_raw”: 1005 ,“chan8_raw”: 198 ,“chan9_raw”: 19 ,“chan10_raw”: 99 ,“chan11_raw”: 22 ,“chan12_raw”: 0 ,“chan13_raw”: 0 ,“chan14_raw”: 0 ,“chan15_raw”: 0 ,“chan16_raw”: 0 ,“chan17_raw”: 0 ,“chan18_raw”: 0 ,“rssi”: 252 ,"_seq" : 166, “_sysid” : 1, “_compid” : 1, “_age” : 66},
“ATTITUDE” : { “time_boot_ms”: 96533 ,“roll”: -0.000983 ,“pitch”: 0.006381 ,“yaw”: 0.104455 ,“rollspeed”: 0.013178 ,“pitchspeed”: 0.009765 ,“yawspeed”: 0.007722 ,"_seq" : 167, “_sysid” : 1, “_compid” : 1, “_age” : 66},
“GPS_RAW_INT” : { “time_usec”: 0 ,“fix_type”: 1 ,“lat”: 290114965 ,“lon”: -821191546 ,“alt”: 44870 ,“eph”: 9999 ,“epv”: 9999 ,“vel”: 0 ,“cog”: 0 ,“satellites_visible”: 0 ,"_seq" : 153, “_sysid” : 1, “_compid” : 1, “_age” : 232},
“RAW_IMU” : { “time_usec”: 96593162 ,“xacc”: 8 ,“yacc”: 9 ,“zacc”: -998 ,“xgyro”: 2 ,“ygyro”: -6 ,“zgyro”: 10 ,“xmag”: 202 ,“ymag”: -40 ,“zmag”: 364 ,"_seq" : 170, “_sysid” : 1, “_compid” : 1, “_age” : 10},
“SCALED_PRESSURE” : { “time_boot_ms”: 96593 ,“press_abs”: 1012.811 ,“press_diff”: -0.558125 ,“temperature”: 6197 ,"_seq" : 171, “_sysid” : 1, “_compid” : 1, “_age” : 10},
“VFR_HUD” : { “airspeed”: 0.000000 ,“groundspeed”: 0.091188 ,“heading”: 6 ,“throttle”: 0 ,“alt”: 0.170000 ,“climb”: 0.010000 ,"_seq" : 157, “_sysid” : 1, “_compid” : 1, “_age” : 124}}
Sent from my iPhone
