Hello, We are trying to build a drone using cube orange as the flight controller and fsi6b as the receiver but we don’t know how to connect them properly because this receiver doesn’t have s-bus pins (has just i-bus ) is there anyone who can help us about connecting them?
Generally it has PPM support. Can you please send the photos of the receiver and transmitter.
I think you have not selected the PPM mode for the RX output type.
You can do that in your TX settings.
Then directly plug the CH1/PPM channel into cube orange SBUS.
That could be true or you can change it to Sbus in the Transmitter and use the same pins. Some support that.
You don’t want the SBUS port you want the RCIN port.
