Huge thanks to DEVs for some increadible code. First VTOL transitions went perfectly
I have spent a few months designing and printing a VTOL. Tri-tiltrotor, 1.7m 3.7kg. Battery 4s4p 21700 - 18Ah. Last week I did some hover tests and apart from ‘temporary’ props causing underwhelming lift and a too weak tilt servos burning out, all went well.
New props arrived and I was finding excuses not to do a transition, convinced I would end up with a bag of bits. Yesterday did QSTAB>FBWA and it was perfect. Clearly the dev team have done an incredible job. Thanks guys.
Minor things I need to look at.-
Still a bit underpowered in hover - new props on order.
Probably I can speed up transitions as they use up about 300m.
On changing FBWA>QSTAB the front motors give a full power kick and cause a large speed increase.
On a WP circle mission it flew outside the waypoints. It looks like the roll P might need increasing a bit.
If anyone wants to browse the file, all advice appreciated. (VTOL second trans)
https://www.dropbox.com/scl/fo/ilmeilnkvkq2a0n7kqkm9/h?rlkey=3dg8ixyk1fowv6o6mrjou781u&st=qtkl8dwb&dl=0
First hover of complete airframe.
First waypoint mission. Cruise set at 17m/s gave current draw of 7A and prop RPM 4000, almost completely silent. It feels happier above 20m/s. 23m/s draws 16A and have had 29m/s from it in level flight. I think speed is limited by low prop pitch but not sure I can increase due hover requirement. Battery is li-ion 21700 4s4p 18Ah.
Hey this looks interesting and promising!
Do you plan to release the 3d files somewhere?
Move the picture to be the first thing in the post and we can make this a Blog post.
OK done that.
20 characters.
Yes I hope to publish them soon. Just want to fix some little issues that showed up during construction. I will probably put them on Cults3D but perhaps there is a better platform?
