In our project we want to design a software about indoor autonomous drone. I want to test my softares on gazebo so I use sitl for that. But when I give takeoff command in stabilize mode with using rc_channels_override message , the drone is moving unsteadly and somersaults. What should I do to takeoff and control the drone steadly without using GPS data?
You can find the code below;
from pymavlink import mavutil
import sys
import time
autotune_bool = False
def mod_change(master , mode_name): #this function changes fligth mode of the UAV.
if mode_name not in master.mode_mapping():
print(‘Unknown mode : {}’.format(mode_name))
print(‘Try:’, list(master.mode_mapping().keys()))
sys.exit(1)
Get mode ID
mode_id = master.mode_mapping()[mode_name]
# Set new mode
# master.mav.command_long_send(
# master.target_system, master.target_component,
# mavutil.mavlink.MAV_CMD_DO_SET_MODE, 0,
# 0, mode_id, 0, 0, 0, 0, 0) or:
# master.set_mode(mode_id) or:
master.mav.set_mode_send(
mavutil.mavlink.MAV_MODE_FLAG_CUSTOM_MODE_ENABLED,
mode_id)
def arming_motors():
the_connection.mav.command_long_send(the_connection.target_system, the_connection.target_component,
mavutil.mavlink.MAV_CMD_COMPONENT_ARM_DISARM, 0, 1, 0, 0, 0, 0, 0, 0)
def autotune_axis():
mavutil.mavlink.MAV_CMD_DO_AUTOTUNE_ENABLE, 1, 3 , 0 , 0,0,0,0,0)
mavutil.mavlink.MAV_CMD_DO_AUTOTUNE_ENABLE, 1, 1 , 0 , 0,0,0,0,0)
mavutil.mavlink.MAV_CMD_DO_AUTOTUNE_ENABLE, 1, 2 , 0 , 0,0,0,0,0)
def set_rc_channel_pwm(master , id, pwm=1500):
if id < 1:
print("Channel does not exist.")
return
if id < 9:
rc_channel_values = [65535 for _ in range(8)]
rc_channel_values[id - 1] = pwm
rc_channel_values[4] = 1900
master.mav.rc_channels_override_send(
master.target_system, # target_system
master.target_component, # target_component
*rc_channel_values) # RC channel list, in microseconds.
the_connection = mavutil.mavlink_connection(‘tcp:localhost:5762’)
the_connection.wait_heartbeat()
mod_change(the_connection , ‘STABILIZE’)
time.sleep(2)
time.sleep(3)
arming_motors()
time.sleep(2)
msg = the_connection.recv_match(type=‘COMMAND_ACK’, blocking=True)
print(msg)
bas_time = time.time()
while True:
code_time = time.time()
if code_time - bas_time <= 2.0:
set_rc_channel_pwm(the_connection , 3, 1525)
