Hello, everyone!
When I armed the APM (3.1.2 heli version), the Tail rotor could rotate very fast, I want stop tail rotor when I armed the helicopter.
My helicopter tail rotor type is “DirectDrive Fixedpitch”
I hope sombody help me!
It is appreciate that if you can give me some hints!
Because I could 't stop the tail rotor when I armed the A{M, so I want copy the 4 channel of function to the 7 channel of function, like 3 channel mixed 8channel in RC, and then output as same as the input, but the 7 channel output very low or very high when I changed the 4 channel slowly.
How to change it? which the MP paramaters will I change ?
Thanks for you help!
I Can’t help you with your DD tail problem. But, I would be very careful mixing channel three with eight. This could cause a crash in a failsafe situation.
Regards,
David R. Boulanger
I think you are right!
But my helicopter have three servos, so I have to use the three channel to connect the servos, maybe I can use eight channel to connect the third servo.
Thanks David Boulanger give me some hints!
You should have no mixing at all in your transmitter.
Regards,
David R. Boulanger
Thanks a lot, David R. Boulanger.
Could you give me a DD tail helicopter mannul about APM setting. I want study the DD tail in detail.
My email address" gaojizhong2008@hotamail.com ".
Thank you very much.
