How to setup max control surface throws correctly?
Hey,
how do i setup my max throws for elevator/rudder/ail correctly? i could not find that in the wiki.
i need max throws of 1300/1700 for my elevator.
do the radio calibration and afterwards lower the “max” values in the settings ?
seems not correct.
or set the max throw range at the transmitter and then do the calibration?
hope you can help me out.
The proper way to set up a plane is to set throws on the transmitter and then do radio calibration. You’ll do trims the same way. I’ll usually re-do calibration after flying the plane and trimming it in MANUAL to capture the correct trim values for the airplane.
