How to set the engine brake
I am configuring an ASW 28 motor glider with FC Matek H743 Wing V3 with Ardupilot 4.5.2. I need to set the motor brake. The procedure I use without the flight controller (radio on, throttle stick at maximum, insert battery, wait for three beeps and music, reduce throttle stick to zero, disconnect battery) does not work. Can you please suggest me how to proceed with the flight controller?
Thanks
Walter
