my drone is stuck in EBOOT or reboot error in Mission Planner’s Bootloader menu, it usually means the flight controller is having trouble booting into the firmware correctly.
Any other steps other than flashing the Firmware of the Drone.
What version of the bootloader do you have? If its 4.6 it might have wiped the firmware.
Yes @andyp1per our bootloader version is 4.6.0.
Is there any option other than wiping the firmware?
@FLDEC_DroneTeam for now I suggest you use a 4.5.x bootloader if you are able.
