I had DGPS constantly feeding in position to the mavproxy thru DGPS module at port 13320.
But it seems that the landing is still about 1metre difference. Is there a way to make landing more precise? I assume DGPS can reach centimeter grade precision, why the difference is in at least 1 mettre?
I now can achieve within 30cm landing without IR-lock.
Anyway in case anyone face the same issue. I realised
Using DGPS module in mavproxy, can achieve about 1-1.5metre accuracy when landing.
manually inject using mavlink and pymavlink. 30cm.
I think something to do with the RTCM. The position in mission planner kept moving around.
I don’t seems to be able to achieve RTK using mavlink without using mission planner. Still trying to figure out how. Only able to get 3D DGPS.
Also I realised if I turn to manual control example poshold or alti hold, there is a lag between injecting rtcm and injected manual control command making it impossible to control safely. I think its necessarily to turn off the rtcm update when doing manual control.
