i changed this parameter MOT_PWM_MAX 1500 and still on all output is full range 997 - 1997 PWM
how i can limit it ?
You have to also have set MOT_PWM_MIN and not be using dshot.
You could also set MOT_SPIN_MAX to 0.5.
This is quite a strange thing to what to do. Why do you need this?
Working perfectly
Thank You !
Iâm continuing my paused project from previous year - itâs big drone with 60kg thrust as paraglider motor but this thrust is too big for drone 12kg after drop it from paraglider
So this is to assist you into the air and then release it and it descends to the ground as a big quad copter?
Yes, itâs a plan⌠instead of a cable winch for thermal flying.
I have tested perfectly funcions small model.
Itâs very very prototype, i know, itâs dangerous but this one will be very carefully tested - itâs only one on all world. What will be in future - i donât know at this moment.
itâs controversial topic
I remember that prototype now! Controversial I suppose but it look like a cool project to me. Very nice job with that Proto!!
