How to improve coverage in Magfit tool?
Hi everyone,
i have testing the magfit tool and the magfit helper with some success.
My only question, it how to improve the “coverage” percentage in the magfit web tool.
with a perfect 8 shaped mission generated with the magfit lua script helper, the coverage only cover about 30%.
have another method o trick or mission movement to improve these coverage?
Even there, the magfit tool have improved a lot my compass interference in the ekf stimator hud and remove yaw reset ground anomaly errors and yaw inbalances at takeoffs
i use too the battery 1 current, offsets and scales
Thanks
Here’s the comment about the coverage bar from the original discussion about the web tool:
Realistically if you’re getting 30% you’re doing really well. May the coverage bar could be scaled for non-acro drones, but for now I wouldn’t worry about it. Sounds like you’re doing well with the tool so keep doing what you’re doing.
This is great information @Allister thanks for compiling in one location, I was wondering the same thing.
