How to connect and configure a MAVProxy connection on RPizero
Hello, I recently build a drone which is connected with raspberry pi zero2w. when I run the mavproxy command I am unable to change any mode, I tried to get map module it refuses rather doesn’t show me anything. I have even tried to reinstall, upgrade and downgrade the mavproxy. different raspberry pi os 32/64. In mission planner I have set baude rate 57600 and MAVLink 1 even tried with MAVLink 2 but no luck. I can change the modes using my transmitter but unable to do that via mavproxy. when I tried to send data to local network I can see it’s connected but doesn’t show any parameters like altitude, gps, yaw, etc.
The correct baudrate for that connection is 115200 and you should use MAVLink 2 protocol on USB or Telem1 port.
Use Ardupilot Methodic configurator to avoid this and other beginner mistakes.
MAVProxy is not correctly connected, if it were you would get the information
I tried that 115200 baudrate and mavlink 2 on uart 3. I forgot to mention that I am using speedybee f405 v4.
