Hi, I have noticed that when I fly fast in PosHold, copter keeps on going for about 10-15 meters when I let the stick jump to middle and I am sure I did not see the copter leaning 30deg to break. In Loiter it stops on almost instantaneously (I know loiter speed much slower).
My current parameters which I believe to be the default:
PHLD_BRAKE_ANGLE=3000
PHLD_BRAKE_RATE=8
1st start by inceasing the PHLD_BRAKE_Rate from 8 deg/s to 12. The if you need more authority increase the angle. I usually just set the angle to the ANGLE_MAX parameter and the rate to 12.
I’m doing the same Gal. PosHold was my primary flight mode for fun flying but Loiters improvements and flexibility have replaced it. Its good for everything!!
Loiter is now the go-to vs POSHold? I have POSHold , althold and stabalize as my main flight modes. Are you saying I should ditch POSHold and go to loiter?
I think so. There are more parameter options to take advantage of. In short it has all the features of PosHold with additional options to tweak. I had the same mode options as you Dave but have swapped them around.
