I want my iris+ drone to automatically carry out the same mission after 1 hour break. Is there a way i could do that. My iris+ drone had copter 3.5 software and auto missions that i have specified
I’m not an expert on this but I think your solution is probably using MavProxy as a GCS?
Create a script that resends the waypoints (if necessary) and the start command 1 hour after landing?
http://ardupilot.org/dev/docs/copter-sitl-mavproxy-tutorial.html
and
This is easily done but it will have to remain powered. Also either disable the DISARM_DELAY parameter (0) or set it for >1hr. The attached will Takeoff, run a 3 waypoint mission, Land, wait for 1hr and do it again.
BTW-For problems like these just run them in MP SITL and see if it works before flying an actual mission.
Problem is you will burn up probably 1 Amp, average quad, sitting on the ground.
Indeed. The Iris isn’t the right craft to perform something like this it can’t carry much capacity.
Yes, I use Venom 5200mAh batteries designed for the Iris on a F 450 that is full of Ardupilot/3DR equipment. It uses about .75 Amps or so just sitting on the ground. I suppose if one was doing a 4 minute flight, rest an hour, 4 minute flight, it would be doable with a little power left.
add a wireless charger to the bottom of it
Thanks a lot…appreciate
Thank you for all your recommendations. Thanks for the problem help @dkemxr . Also what drone do you’ll suggest for a project like this
The drone will be automated. Then will be stopped at a point for charging and then go on charging once it is fully charged wirelessly at its base station.
Please suggest a rugged drone with long battery life and sustainable to continuous missions like these.
I can’t suggest a Drone to accomplish this. Typical flight times are 30 minutes max* and wireless charging is not practical for this application.At least not anytime soon The chargers available today are like 10w, For every 30 minutes of flight time it would require a day or more of charge time. Even Apple couldn’t get it right, they canceled their product.
*I built a 550 size quad that would fly for ~40 minutes but it wasn’t carrying anything. No camera, no gimbal, no FPV, nothing.
@dkemxr Can i use multiple wireless chargers? And my application can have a 12 hour+ rest time…My main concern is that will there be a mishap due to continuous charging and discharging for a long period. How do you suggest that I get a flight time about 30 min with a raspberry pi and pi, a portable charger and Pi camera on board?
I suppose you will have to build it. Look at the 600-700mm frames available and start configuring using eCalc. Start with 6S power.
Again, I don’t think wireless charging is a practical option. There are charging pads available that make contact kind of like a slip ring brush. Very expensive but you are not going to do this on the cheap anyway. Landing on the charger is another issue. Typical GPS will not be sufficient. .
@dkemxr would you be interested in making it in a time period according to our requirements…
if i can fund you?
As much as I like to build RC vehicles (Multirotors, Planes, Rovers) I wouldn’t want to take the responsibility for someone else’s craft. I build at the Hobby level for fun. I have seen posts on here though from people that do offer that maybe someone will step up?
Thanks for all your help…do help me connect with people who will be interested
