How fast can I go in auto mode? Which parameters should I change? Which problems can happen during fast flight? Thanks
Vibrations are the main issues I hit when developing a high speed aircraft.
Haven’t tested more than 20 m/s - but there really isn’t a limit put in place.
Change the WPNAV_### paramters.
Thank you. Has anyone tested more than 20 m/s?
You are the test pilot. Post your results.
Ok I will share my setup and results 2 months later.
