How do I program my remote ID for the X4 drone?
I have it connected, but I keep getting this PreArm: OpenDroneID: SN issue. Im not sure wha it means but I need help on trying to gettign rid of the pre arm so that we can fly the drone
OpenDroneID (some sort of Remote ID) needs to have the Serial number configured. You have skipped that, hence it correctly refuses to Arm.
User error.
I have the serial number but how do i configure it so it removes the pre arm?
You need to correct the serial number format. You entered too many or too few digits or something like that.
You must not remove the prearm.
The prearm is not the problem, the incorrect serial number is the problem. Fix the issue at the root.
Enter the serial number format into Mission Planner, or is there a separate app on getting the remote ID started? it is just a standard Aruelia X4 remote ID that comes with the drone
The drone probably has a user manual explaining how to enter your RemoteID.
Did you looked for that? Did you ask the person that sold you the drone?
I am working for my university right now for a competition and this drone was passed down from another team last year, I did look into the user manual for the Aurelia X4 but there is very little information on the Remote ID as it just says what the colors mean but not how to connect it because mine doesnt even load into the Mission Planner for some reason .
Ask the professor then. He did give you a valid RemoteID right?
I’m pretty sure it is valid, I mean, it was used by the other team,m so it should be good, and I can’t really go to my professor because the class I’m using it for is my senior design project,ject so he doesn’t specialize in drones, just mainly electrical engineering.
