I’ve now got my TRex 500 flying the way I want it, with Arducopter 4.2.1. As a newbie to Arducopter in helis, I played safe and placed the GPS/compass unit quite a distance from anything else, as you can see in the photo:
In the future I want to use the same system in a TRex 500 with scale fuselage, so need to bring the GPS/compass closer to the frame. Apart from trial-and-error, are there any rules and/or suggestions regarding its positioning?
E.g. is the ESC a bigger source of interference than the motor?
Do the servos or the moving mechanical parts create much interference?
Would positioning the GPS/compass off the front of the battery tray (requiring longer leads to the FC) be a problem?
Every esc is different, every GPS antenna is different.There is no magic distance number that fits all. You need to test it and see how much it drifts and glitches.
Your spacing should be fine. But you could always mount it on the tail boom, thats where i put mine to get it away from all the motor and battery wires.
Then it would be closer to the high current carrying cables from the battery. Maybe it’s a bit more noisier for the compass…
I wonder how much the blades would influence the GPS signal, since carbon fiber does have some RF shielding properties… That is of course if you are using CF blades
They are cf blades, JaSw, but all appears to be good. Wherever you place it, there’s practically no way not to be beneath the blades
GeoMuir, I had originally though of the tail boom, but a forumite’s picture convinced me to put it where it is, close to the fc. But tail boom is not going to work for the scale fuselages I’m hoping to put the system on next. My two scale helis are a TRex 500 with a Hughes 500 fuselage, and a TRex 550 with a JetRanger fuselage. Both of them might be able to accomodate a GPS unit mounted like I have now, but much lower down. I don’t think either have space in the tail boom, unless it’s external, which I don’t want.
So, a lot of planning to do before I install anything in my scale helis. In the meantime I have a working benchmark with this heli which I’ll be able to compare with different GPS placements. I’m going to start by lowering the GPS mounting mast by about half its height. If I need to put it at the front, I suppose I could screen the GPS cables within a grounded tube of wire braid.
You dont need the gps away from the high current wires but the compass, so you could get a standalone i2c compass and place it in the tail, its about the size of a postage stamp and weighs nothing so you could fit it in the tail much easier and have the gps mounted lower down or have it on the nose above the battery.
The three wires from ESC to motor are inside the frame, and the FC is mounted outside the frame the opposite side from the side you see in the picture. So, yes, I suppose the compass in the FC is closer to those wires than the compass in the GPS module.
Lots of issues to consider when planning a layout! Thanks GeoMuir.
I only fly scale helicopters, but usually larger ones (700-800). Here are a few of my experiences:
Stay about 5cm away from servos with the GPS/compass.
Stay as far away as possible from motor and controller and wires. At least 5cm plus.
With a belt driven tail, stay at least 5cm plus away from the belt. This charges with high voltage!
I do not use the internal compass. In no model of mine.
The best position in a scale helicopter is in the nose. In the following order: GPS/compass in front, FC behind. Here you may need longer servo cables from the FC to the servos. Take thick extension cables and twist them together. The FC does not have to be directly in the center of gravity. If this causes problems, you can tell the FC the deviation from the center of gravity via parameters and the FC will then convert the values accordingly. As a rule, however, this is not necessary. Your fuselage should be connected as vibration-free as possible with your mechanics. I glue a stable plywood board in the nose floor (e.g. under the cockpit) and attach the GPS/compass and the FC to it.
You can easily test this by attaching a stable wooden stem to your mechanics (leave out the canopy), attach the GPS/compass and FC there and fly.
I had a good look at my scale helis yesterday and I’m pretty sure the FC can fit on the side of the frame, at the rear, as it is now on my bare TRex 500, which seems to be working well. I’ve now lowered the GPS/compass unit by 1" (25mm) from where it is the the above photo (and recalibrated the compass), and it looks like it might even fit inside the Hughes 500 fuselage at that location. It’s now about 6cm from the rear servo. But in the nose was my first thought, with a plywood or fibreglass mounting plate as far forward as possible. The tails of all my helis are TT, so no static problems from a belt. The front ends of my fuselages are both held on by magnets and location pegs, so I don’t think are going to cause any vibrations.
