I am working on an interdisciplinary neuroscience/robotics research project at my university, and I am banging my head against a wall trying to figure out how I can simply call the quadrotor to takeoff withing the Mavproxy console.
For example, I might be in Manual Mode, and say $ arm throttle, but I cant actually get any kind of behavior from the drone itself. I appreciate the time taken for your responses!
You should switch to guided mode first. Then type arm throttle
, then quickly takeoff 5
or some other altitude you want and there you go…
Thank you so much. When I type $ mode, ‘GUIDED’ is also not listed as an available mode. The commands still execute in MANUAL however
