How can I get the desired angular velocity, like getting the desired roll, pith and yaw in the ATT log
Hi dears, I hope to get the desired angular velocity, just like the desired roll, pith and yaw in the ATT log.
In addition, I also want to obtain the desired position vector value and the desired value of the vehicle speed.
How should I get it from the log, or record some values in the ardupiot code to get?
For example, I use (mavlogdump.py --format csv --types IMU LOGPATH.bin> LOGCSV.csv ) to get the following information. But there is no desired angular velocity value, only the angular velocity measured by the gyroscope.
Thanks!
Which programming language you are using? For example you can convert bin log files to mat using mission planner and you can read the logs in Matlab
After I get the .bin log, I will use mavlogdump.py to convert the log into a csv file. Another problem is that the log types that mavlogdump.py can convert are as follows.
but there are some abbreviations that I don’t understand.Some abbreviations are explained in this website https://ardupilot.org/copter/docs/common-downloading-and-analyzing-data-logs-in-mission-planner.html.
Did you look at this?
Thank you very much, this is the abbreviation explanation I need to look for。
