I am writing a somewhat elaborate app in Java that needs to know the quadcopter’s GPS location. The app will be runing on a laptop that is also the ground station computer, running Mission Planner. Is there any way I can read GPS information programmatically?
I have a 915 MHZ 3DR link in place.
I can write any code I need for the RPi. I also have a 433 MHZ link I can use if it might be part of the solution.
This application also needs to read RSSI off a software defined radio that is running on a Raspberry Pi on board the quadcopter. The RPI will be connected serially to a Pixhawk controller.
This app is for amateur radio foxhunting. I am writing code to use multiple RSSI, location and altitude points to derive the location of the fox.
Can anyone recommend a best approach, or architecture?
Thanks in advance for your comments.
John
