Hot ESC's and Motors after a short flight
I am trying to figure out why I have warm motors and ESC’s after a very short flight. I don’t believe it is a tuning issue, but I have been wrong lots. Maybe an esc setting issue?
I have changed ESC’s, moved them directly under the prop wash. They are still getting 70-80c (ESC’s) with a thermal temp gun, hot to touch.
Any help is much appreciated.
Bin file…
Here are the exact sequence of steps to debug and fix it
Although this is not a *.bin log, and plot.ardupilot.org is incapable of opening it, I don’t see any large-scale oscillations, that usually make things hot, by grepping and sorting through the log.
In particular, none of PID*.{P,I,D} entries are particularly high, and RCOU entries are just as smooth as the “corrected” log by the link you provided.
I don’t think it is “solved”.
There is one thing in the logs that I found somewhat suspicious, and it is that VIBE from IMU2 is much higher than from other IMUs, sometimes reaching 40 in X.
I guess the presence of such a difference is the usual thing in CubeOrange and other similar controllers where IMU2 is not internally dampened - but this suggests that something wrong might be happening physically in the frame.
Which - as a wild guess - might be a consequence of ESC/motor pairs be occasionally unhappy with each other and/or with the incoming signal, resulting in desyncs, hard shakes, commutation problems and overheating. This is, of course, way too wild to be the only hypothesis.
A thing I would recommend trying is to get to 2kHz of DShot, which amounts to SERVO_DSHOT_RATE=5 (edited from initial incorrect 4). There is a word of mouth that AM32 loves higher freq communications. But I am not sure this will fix things.
You may want to provide more details about your setup (motors, props, weight, whether we can trust the current readings).
Thank you for the feedback,
DSHOT is already at 4.
10in props, oddityrc 65amp esc’s, genaric 3214 1000kv motors.
Sorry, I meant 5, not 4. 4 is 4 * 400 = 1.6kHz. But you can set 5 (and higher).
Sounds good thanks for your feedback
Try dropping the Rate-D terms a bit. Not much else to see here. Was this a typical Auto Tune at the default aggression?
Usually you need Complementary PWM enabled, enabling Auto timing advance might help a bit with heat.
I believe it was at typical autotune aggression, fiddled a bit with the pids after though. I will try dropping the rate-d and see if that helps any.
I do have a question if maybe this could be the issue.
The motors are generic cheapo motors, I guess bad build quality motors could cause this?
Dropped the D-term and didn’t cool off the esc’s or motors.
There’s some motor mount or arm twist, since the outputs are grouped into CW and CCW motors. It’s not a big issue but everything helps.
I suggest dropping the initial harmonic notch filter frequency to 60 Hz since the existing value of 86Hz is extremely close to the motor noise frequency of about 91 Hz, leaving no room to move lower if required.
The frequency (and bandwidth) will scale up with the ESC RPM so setting it low is good.
Also increase the attenuation a bit, or you may as well just disable the notch filter.
INS_HNTCH_ATT,20
INS_HNTCH_FREQ,60
Other than a little nervousness in the attitude control, I could not see any special reason the ESC heating. The problem may well be poor motors.
You could try lowering all the ATC_ACCEL_x_MAX values by 10% and see if that helps. Round them down, a couple of digits and decimal places doesn’t make any real difference.
It would be nice to see a new log after those slight alterations, and with some harmonic notch filter data.
INS_LOG_BAT_MASK,1
INS_LOG_BAT_OPT,4
My experience normally it’s a wiring issue or damaged motor coils if tuning does not fix it. Long m3 screws will overheat a motor right away. Sniffing check is a good idea. Also as a side note if your hot I would remove the spark cap in case the heat shrink bridges the wires and crashes the FC.
Shawn, I dropped the ATC_ACCEL_x_MAX as you advised. I didn’t yet change INS_HNTCH_ATT,20 Wont this for a hexa overload the FC?
INS_HNTCH_FREQ,60
I was trying to understand the why for dropping them and I wanted to get you a new .bin file because a changed my motors since the original file above. The esc’s are some cooler now but the motors still get warm. The motor arms are a flat carbon fiber plate, I’m not sure how they got/are twisted or how I fix that. The linked .bin is on a slightly windy day (9mph).
I guess I should add that this is a hexacopter. I am sure that you saw this in the settings.
I just updated these…But it was after the .bin flight below.
Here is another one…
Not sure what all has been covered but did you try with Complementary PWM enabled?
@mike_tk @dkemxr @xfacta @MaxBuzz Thanks for the help. Turned on Complementary PWM and they are 30c not even slightly warm.
