Home point updating on Arm
Is there a way to stop the home point updating on the initial arm procedure? I want it fixed till i move the location myself. Cheers
Hi @Resny73,
If you manually move home from the ground station then it will not be set during arming.
If you’re looking for more special behaviour then Lua script support setting the home location. Here’s an example script.
