I am now a little bit confused. I know that Kakute F7 AIO supports OSD. In the Arducopter Wiki it says the Normal Kakute F7 does not support OSD, but searching the net there are some saying that they use OSD with Kakute F7.
Do both Kakute F7 support OSD or only the AIO?
I don’t see in the Wiki where is states it’s not supported.
This is what it says:
Both variants include a 5-volt regulator rated for 2 amps, OSD, vibration-isolated IMU, etc.
Hi Harald,
I wonder if that’s right for the Kakute F7 regarding feature limitation. Because it also lists the Kakute F7 Mini but in Hardware definition it’s shown as supported.
And the F7 and F7 AIO use the same hardware definition file and it’s supported there as well. So I’m wondering if the feature limitation doc is wrong to list OSD.
Perhaps @hwurzburg can take a look and confirm the Feature Limitation doc.
