Hi everyone,
I have a couple of doubts regarding EKF3 configuration while using the H-Flow sensor and would appreciate your guidance.
- As recommended VELZ Handling (EK3_SRC1_VELZ = 0)
I have configured:
EK3_SRC1_VELZ = 0(None)
So there is no vertical velocity sensor configured.
In this case, from where does EKF estimate VELZ?
- H-Flow Usage and GPS Switching Above 30 m
I am using the following configuration:
EK3_SRC1_POSXY = 0 (Optical Flow)
EK3_SRC1_VELXY = 5 (Optical Flow)
EK3_SRC1_POSZ = 1 (Barometer)
EK3_SRC1_VELZ = 0 (None)
EK3_SRC1_YAW = 1
EK3_SRC_OPTIONS = 0 (FuseAllVelocities disabled)
The H-Flow sensor has a maximum reliable range of around 30 meters.
My concern is:
After crossing ~30 m, Optical Flow will not be reliable
In this case, how does EKF handle POSXY and VELXY?
How can I automatically switch to GPS above 30 m altitude?
FuseAllVelocities Option
Ardupilot recommended settingEK3_SRC_OPTIONS = 0(disabling FuseAllVelocities). -
Would enabling FuseAllVelocities provide better robustness by allowing fusion of multiple velocity sources?
- What is the best recommended setting for
EK3_SRC_OPTIONSfor our use case (Optical Flow below 30 m and GPS above 30 m)?
