Holybro and Cube Orange telemetry problem
Hello, can someone find my solution that I have been looking for for days.
On a drone equipped with an orange cube I put a Holybro V3 433Mhz telemetry and the problem is that my telemetry connects but stops giving me the message: “got param STAT RUNTIME” which means that I receive parameters like height, compass direction… but I can’t access any parameters, I don’t have all the menus.
Another curious thing is that if I plug my Pixhawk into the usb socket and connect via telemetry it works, however I can’t save the changes I make.
Thank you
Maybe the voltage is too low, and the extra current from the USB cable bumps the voltage up a bit?
Thank you for your reply. I found the reason for the malfunction. It was because I had 2 devices on the same serial port. I fixed that and everything is working fine.
