Hello.
I made 2 Quadcopters with X9 Motors on the chassis of EFT.
I have X7 + Pro Flight controller in the configuration and I have no compass problem with Baseline yaw heading.
There is no problem with the device and it flies very well.
My other device has a vertical vibration starting after 40 seconds of the video. https://www.youtube.com/shorts/IUGt7nlMeHY
I am doing ArduPilot methodic configurator manually but I need to fly stable in ALTHOLD mode for NORCH filtering but it vibrates in althold mode and I could not find the reason.
The AMC Tuning Guide does not present all the details.
It is already very long, without all those details.
And there are automation steps that can only be done in the software.
Hi @idris,
I reviewed your log, and my initial thought is that the oscillation in all IMUs’ Z-axis after entering ALTHOLD mode, based on the oscillation frequency, seems more likely to be caused by Z-axis vibration rather than the posZ controller’s aggressiveness. Do you use a vibration mount?
Actually, there seems to be an oscillation here.
I haven’t flown enough to warm up the engine.
I actually made the Initial Tune params settings exactly.
