Hello everyone!
I encountered a problem when working with an ESC that was flashed with the AM32 NeutronRC_G071 firmware. The remote control outputs throttle values in the range from 1150 to 1950. I entered the value in the ESC settings. However, when using the Dshot protocol, the ESC works only up to the maximum value of 1940, with a further increase in the throttle value, the ESC stops and cannot initialize, since it does not understand the signal that comes to it. I tried increasing the high threshold in the ESC settings to 2025, but nothing helped. It seems that this is a built-in upper limit that we cannot change.
Has anyone encountered something similar?
AM32 range applies only to PWM. Since you are using AM32 configure BDshot for telemetry. You should do RC calibration in Mission Planner.
Can you please post a .bi log file?
