I made my pre-flight arrangements properly. In Hover Learn mode, I flew on the axes and adjusted the ths_hover and PSC_ACCZ_I and PSC_ACCZ_P parameters 3-4 times. Problem: My Hexacopter behaves strangely in modes such as poshold and land, especially in land mode, it slows down its speed very quickly and oscillates. When I looked at the RCOUT values, I saw that the thrust was sufficient. What do you think is the reason? Can you help me?
Since I cannot do this part, I cannot move on to parts such as harmonic notch filtering or autotune. Can you give me a different tip?
FCU: Pixhawk2 Cube Black
GPS: Here3 only Can1
Prop : Eolo 17x6.2
Motor: Sunnysky V5210
ESC: Skywalker 60A V2 (I am not using feedback cables yellow and white ones)
Bat: 16000 mAh 25C
Weight: Estimately 5-6 Kg
have you calibrated the ESC? Your Motor minimum looks unusual in my experience.
Have you set the MOT_SPIN_ARM and MIN wrongly from the Motor Test UI? I think you need to find out your ESC/Motor MOT_PWM_MAX and MIN. I think Skywalker is 1100 - 1940 us / 1960, cannot remember. Maybe enable this LOG_FILE_DSRMROT,1.
I am also curious whether you will hit the underweight issue running at a low motor percent curve. 17" prop → (2.806kg x 6 / 2.4) = 7.015kg.
