Hexacopter 550mm having impulsive twitching
Hi , during the first test flight of hexacopter with radiolink cross flight fc i observed some momentary impulsive twitching to one side I can’t understand what it is it’s like i applied some rc input and I also have attempted a auto tune which was not initiated by autopilot
And im not able to find the cause of this with my limited knowledge in reviewing a log I have attached the log and help me if any thing is wrong
Bin files
https://drive.google.com/drive/folders/1Cjt3CRZN4HqzZXrDGM3dwQWgh-3si9W5
Hello @Greyhound
because you have limited Knowledge, it makes more sense to prevent the issues from happening in the first place instead of trying to fix the issues without understanding them.
By using the software you will also learn a thing or two, making you more knowledgeable.
Thank you for your time I’m a student and it’s part of my project I’m trying to learn all this, but I can’t analyse what the problem is with the setup
I know that is why it is recommended to:
Instead of analyzing it, prevent it, using the software provided.
