I am on the edge of getting this flying in stability mode. However, the copter starts to yaw immediately upon liftoff. Not just a little, but crazy yaw. I throttle down immediately.
I have gone through the setup via MP several times. I saw mention that might be a motor not spinning the correct direction. I verified they are all correct.
Another mention was a loose propeller. These are the self-tightening so I dont think that is it.
I even went through the process of ESC all-at-once calibration even though everything else I have read seems to indicate that the DJI E300 OPTO ESCs don’t require that.
I uploaded the log file here:
https://www.dropbox.com/s/t2x03nkbv1pf64n/2015-03-11%2019-09-38.bin?dl=0
I had set the bitmask to the next highest, hopefully that will have the necessary data if someone can take a look see.
Thanks in advance as always
Sandy
