I am running Copter 4.6.3 with a Cube Orange Plus.
Here is the Fd Up Copter Params.
The Problem:
Here4 GPS module is now Breathing Red. No compass is recognized and no GPS recognized when looking with SLCAN. Here4 module is not seen in DroneCan, MavlinkCAN1 or 2 or MCast 1 or 2. Nor is anything showing in CAN GPS Order under SETUP. HW ID shows only the Cube Orange Plus’s internal I2C compass which calibrates and functions fine.
HW ID PIC:
What Happened:
Assembled the drone, it worked fine, GPS worked, compass worked.
Some flights later I get a Breathing Purple light on the Here4. No idea how or why it was able to determine it needed an update but it did. Drone was not flyable while the Purple dragon was breathing.
I looked into this and found what Breath Purple means.
I also found this saying if it is not booting to Breathing Blue then it needs an update.
Ok, updates are great! Let’s do it! I’ll use Mission Planner version 1.3.83.
After MUCH messing around I was able to “see” the node ID #125 Here4 module using the MavLinkCAN 1. It never wanted to show up on the normal SLCAN. I clicked on UPDATE and it updated with the FW version for compass default type RM3100. I SAW IT UPDATE. It was successful. I also want to say it updated to version 2.0 but I can’t be sure. I can only find version explanations here but DO NOT KNOW where Mission Planner found the FW firmware that it used to update the Here4.
Now she boots Breathing Red.
What I’ve Been Able to Tell:
All signs point to a messed up DroneCan node setting somewhere but I’ve checked my parameters against a working version of this drone build (WORKING FOR NOW THAT IS). Constantly I am seeing things like this:
And this:
I can confirm that these settings below are correct:
Go to Config - Full Parameter List page and modify the following parameters:
CAN_D1_PROTOCOL: 1
CAN_D2_PROTOCOL: 1
CAN_P1_DRIVER: 1
CAN_P2_DRIVER: 1
GPS_TYPE: 9
NTF_LED_TYPES: 231
More Clues:
*I have an untouched Here3+ module that I plugged in after removing the Here4 module. I was unable to get it working. Again, all settings for a normal install are correct, it seems to be a messed up CAN bus problem.
*GPS1_CAN_NODEID is 0 instead of 125
Similar problem: Here4 not visible on SLCAN after Firmware Update - #9 by JuanB - Here GPS - Cubepilot
I keep seeing garbage on this feed:
