Here 4 GPS as an autopilot
Hi
Recently I purchased a here 4 GPS and found a mini computer with it. Once checked, I got to know that it can be used as an autopilot. I researched about the same but didn’t get any lead regarding the same.
Has anyone ever used here 4 GPS as an autopilot and if yes, can you guide me?
AFAIK it turned out to be a gimmick as GNSS and FC placement requirements are contradictory and CAN enabled hardware isn’t as popular as some would have hoped.
One serial port and 2 CAN ports. Maybe it would make an expensive Tracker controller !
But cheap L431 AP_Periph boards can be used to extend it right?
I guess you could do that.
The Cube Pilot docs make mention of a breakout board but then says
“Current firmware does not support this function”. Not sure if that is up to date and what breakout board?
