Heq Swan K1 - Pitch Oscillation in forward flight
Hello everyone,
we are currently trying to use a HEQUAV Swan K1 Pro (doesn’t seem to be identical to the Swan K1) with Ardupilot. Flashing worked, but forward flight needs some more tuning. My previous experience with fixed wing flight is limited at best.
We don’t use the original Battery and currently have no payload.
In the current state hover flight modes work well and the transition as well, but in FBWA there is quite a severe pitch oscillation which I can’t seem to get tuned out. I’ve tried moving the CG back a bit, which doesn’t seem to help. Pitching up helps and it get’s worse with airspeed.
Here is a log:
Well, it seems to have been my inexperience. After choosing a lighter battery and more nose weight, it flew somewhat decent.
If anyone needs the info: The CG I’ve landed on was approximately 6cm behind the furthest forward point on the wing
