I perfomed a flight to gather raw imu data to put in the filter review tool but i am not sure if i understand the results of if there is something wrong.Could i get some feedback?
Thank you.
Thank you.
Set the log bitmask back to default and the check the Fast Harmonic Notch Logging box. And then make another flight.
Thank you for the help,should i also enable the Raw imu i am using a pixhawk 6c?
No, not needed. Just set what I suggested.
