Help with tuning
Hi everyone first post long time user. I am trying to build a drone with an ssh to a raspberry pi. I have it hooked to a pixhawk cube orange. Motors are cobra 4008 400kv on Hq 12.7x3 props with a light payload and gimbal, 6s 10,000Mah Li-on battery. I am stumped because I set it up in the initial tune correctly. Went to arm in stabilize mode after doing all of the calibrations needed. I checked the motors and props they were calibrated and in the correct orientation? I have the T/R logs to see if that sheds any light but I am trying to get a stable tune for this aircraft ASAP.
Hi long time user
You may not be aware of a new friend in the circle.
this statement ended with a question mark. double-check it out here. What is your ESC type? normal or Digital ESC?
So the ESC is the diatone mamba running Dshot 600
