Help with new build Tradheli and first hover stability
Version: Copter 4.7.2
Frame: Roban 470 cobra
ESC: Stock Roban 470 60A Daul ESC
FC: Pixhawk 6C
GPS: Roban stock GPS
Battery: 4s 4800 mAh
Tx: RadioMater ERLS
Hi - I am new to building traditional heli using Ardupilot. I have been following the wiki and have managed to get the heli up and running. I have gotten to the step of trying to get a stable hover, before moving on to autotuning. However, I just cant seem to get a stable hover without putting in forward pitch and right roll. I also am having an issue where the tail motor seems to spin up too fast causing the tail to swing to the left(Video attached). I am looking for some help in getting a stable hover so I can move to to Auto Turning. The only knowledge I have is what I have followed in the Traditional heli wiki. I have log files but not sure which to upload as some of them are large in size. I have attached a pic of the logs, if someone would be so kind to tell me choose which to upload that would be great.
Pic of logs: https://photos.app.goo.gl/pz4mBSw5EnLTAB7R7
Video of tail issue: https://photos.app.goo.gl/5N8CPdgpAdiHjq3J7
Thanks
Rob
Best to share one .bin log of recent flight. Don’t share a folder of a bunch of logs because that’s just frustrating. Most likely it’ll be the last complete flight.
Assuming the weight and balance is correct you can start with the trim:First Flight Tests — Copter documentation
Very often a small amount of input corrections will be required even in a stable hover. Its its taking a lot more than you feel like it should here are some things you can check:
level on the swash plate
Accel Calibration
Accel Level
Also for helis ATC_HOVR_ROL_TRM has to get fine tuned too
As for the DD tail H_YAW_TRIM might need adjustment but there is no ramp up on the DDFP tail motor for this version of ardupilot I don’t think (in the works IIRC).
Will do. I have already done the steps in that documentation.
Log file: https://drive.google.com/file/d/1dTvjGZTQkiyGoOlP9-IL58ojMMz-eh0r/view?usp=drive_link
Log is password protected. You’ll need to fix that.
Should be open now. Please try again.
Reset the PID values based on the tuning instructions:
Let’s try some simpler filtering:
Try a hover with that in Stabilized. There might still be some trim issues, and it’s up to you to make sure that everything is mechanically sound (swashplate level, links set, etc) but I think you need to clean up the noise before adjusting trim or PIDs.
Ok, Thank you. I will go back and do all of what you suggested and let you now the outcome. I will also upload the logs from that hover.
Ok I reset PID as instructed. Only issue I had was ATC_RAT_RLL_P and ATC_RAT_PIT_P was out of range error. everything loaded no issue. Did a test hover and the first thing I noticed is that the tail settled down a little. I still had to hold a fair amount of right stick roll and forward pitch to get it stable. Logs files: Logs - Google Drive
Did you do anything that would change the RPM? I see the commanded output to the ESC is the same, but the peak frequency looks like it’s gone up by 100 or 200 rpm.
The warning about the PID values is based on multi-rotor firmware. You can ignore that and write the params.
Are you sure the swasplate leveling has been done? The gaps between target and actual still seem big. More than just trim.
I’ve also noticed that you’re launching without GPS location. Okay at this stage since I don’t think RTL would end well, but you should re-consider that as it may burn you later on.
Hi Allister, Just wanted to say that I am grateful that you are helping me, thank you. If I made any changes it must have been after I sent you to first logs. I don’t recall but I could have in my efforts to fix the issues. I will go back today and recheck the alignment and swasplate leveling, but I was fairly confident the last time I did it, things were level. As for GPS, I know that I have been, but seeing that the tests are being done in stabilize mode I wasn’t too concerned. Will recheck everything and do another hover test and then upload logs.
Ok, new logs are here: Logs - Google Drive
I went back and relevel everything but changed no other settings otherwise.
The leveling sure helped. Roll looks better. I’m still worried about pitch. When you did the leveling did you verify the mast was vertical? The nose of the helicopter is sitting too low. So something in the pitch needs to be adjusted. If you have the helicopter leveled with the mast perfectly vertical then I would suggest adjusting the CofG to bring the nose up a couple of degrees. Or possibly adjusting the servo 3 trim. It’s not going to need a lot.
Here’s Bill’s video on setting this up.
I’m also worried that the RPM keeps changing. Luckily there isn’t a lot of noise in the system but it seems every log the vibration peak frequency is different. I don’t know enough about the hardware you’re using to suggest why that could be an issue. It’s not the parameters because the output to the ESC hasn’t changed. This could make further tuning really difficult because the responses will keep changing.
The pitch concern stands out more than roll, since a nose-low attitude on a leveled mast can mean the CoG is off rather than a servo issue. Worth checking balance before trimming servo 3, because trim would mask it. On the changing RPM peak, does your ESC log show a consistent throttle output? If the output is fixed and the peak still moves, the cause is likely mechanical or governor-side rather than a parameter change. Repeating the hover with the same setup would confirm whether the peak drifts consistently or randomly.
Man, this is way more involved than I expected but I am willing to learn and get it right as I do enjoy the hobby. I will get back and check CofG. I am not sure where the RPM reading would be coming from, it must be over the ESC connection to the FC. As for the ESC there is not much I can do with it as it’s locked down and not much info is available from Roban about it.
Ok, here is the new log just doing another hover with no other changes aside from moving the battery around a little to get a better CofG. Logs - Google Drive
